eigentlich sollte so eine Steuerung über den Data Model Designer möglich sein, indem man eine Klasse einem Mechanismus zuordnet oder eben nicht. Habe es aber selbst noch nicht ausprobiert. Aber im Program Directory zu V5R11 SP5 habe ich folgendes gesehen, was vielleicht weiterhilft:
Drawing & Link exposure in expose mode
The CATIA-SMARTEAM integration can be customised to expose the drawing sheets ("expose mode").
In the case of the expose mode, the user may choose or not to expose only the links between the sheets to the external documents and not to expose the links of the drawing document to the external documents. This section explains the option required to customize the drawing link exposition.
Links exposed from both Drawing and sheet to the referenced documents
In this case, the sheet will expose its direct dependancy links and the drawing will expose all the sheet dependancy links. This is the default behaviour.
In case of error, the user should check that the variable CATIA_TEAM_PDM_DRLINK is not set.
Links exposed only from the Drawing to the referenced documents
In this case, the sheet does not expose any dependancy links. The variable CATIA_TEAM_PDM_DRLINK should be set to DrOnly
Links exposed only from the Sheet to the referenced documents
In this case, the drawing does not expose any dependancy links. The variable CATIA_TEAM_PDM_DRLINK should be set to ShOnly
